Assembly services
Did you know that you can buy assembly of your stairs directly from us? You basically always get the best results when you buy the stairs with assembly, but of course there are times when this is not possible and then there are other options that can simplify the assembly for you as a customer.
Installation on site means that we take responsibility all the way from your order to inspection and that is the absolute best when it comes to minimizing errors. If you buy the stairs with assembly, the measurement is often also included so that the measurements are also correct and a certified fitter, i.e. a carpenter who has undergone our assembly training, who comes to your home or to the construction site and takes care of the entire installation. When you buy one or more stairs including assembly, we deliver the parts in flat packages. It is a good environmental choice because we can send many more stairs in the same delivery and better for the working environment as heavy lifting can then be avoided.
If for some reason this option does not work for your particular project, we can offer factory-fitted runners to make installation a little easier.
Factory fitted runners means that we assemble the stairs in two to three parts, which are then lifted into place on the construction site. It is a time saver for many construction companies on large projects where the stairs must be assembled by their own staff. It reduces the risk of errors during installation, but it is also a heavy job to lift the parts into place and in most cases requires at least 3 people. When you order, you let us know that you want the stairs mounted in a run and we will sort it out. Take the opportunity to order step protection at the same time so that everything is in place when it arrives at the construction site.
