Staircase with glass railing – elevate your home with light and elegance
Create space with a staircase with glass railing
Choosing a staircase with a glass railing is a great way to combine modern design with practical benefits. Glass railings have become increasingly popular as a stylish solution for indoor staircases, and their elegant appearance makes them an attractive option for many homes. Drömtrappor offers several options when it comes to staircases with a glass railing, making it easy to find a solution that suits your home.
A staircase with a glass railing is a great way to give your home an airy and elegant feel. By letting light through, it helps to make the room feel larger and more inviting, which can enhance the impression of both small and large spaces. For example, a narrow staircase can feel wider and more open thanks to the transparency of the glass. Drömtrappor offers the opportunity to design your own indoor staircase with a glass railing, whether you prefer a minimalist, classic or modern style. The flexibility and aesthetics of the glass railing make it a timeless choice for any home.
Safety and function
A staircase with a glass railing not only offers elegance but also safety. Glass railings are made of tempered or laminated glass, which makes them extremely robust and safe. They are also easy to keep clean and require minimal maintenance.
Different types of glass railings from Drömtrappor – stylish and adaptable solutions
Drömtrappor offers a wide range of glass railings for stairs, each with unique features and installation methods to suit different styles and needs. Here are some of the most popular options:
Staircase with glass railing between clips (GC)
  • Model: 4.GC.1
  • Description: The glass is mounted between wooden or stainless steel posts using specially designed glass clips.
  • Features: Can be adapted to different stair shapes, including special solutions with curved glass, making it both flexible and elegant.
See an example of: staircase with glass railing between clips
Staircase with grooved or framed glass (GS)
  • Model: F.GS.7
  • Description: The glass is attached in grooves between the stringer and the lintel for seamless integration. The glass is framed by the stair posts, lintels and balusters.
  • Properties: The framing of the glass creates an elegant and stable construction where the glass becomes an integral part of the staircase design.
See an example of: staircase with grooved or framed glass
Staircase with bolted glass railing (GB)
  • Model: 0.GB.20
  • Description: The glass is bolted to the outside of the side piece for an airy and modern feel.
  • Features: The bolts in the side piece mean that no extra post or railing post is needed to stabilize the railing.
See an example of: staircase bolted glass railing
Staircase with glass railing, concealed fastening
  • Model: Drammen
  • Description: The glass railing is mounted between two side pieces to create a clean and stylish appearance.
  • Features: Perfect for modern interiors, where a minimalist and discreet design is desired.
  • With these options, Drömtrappor offers the opportunity to create a staircase that is not only functional but also a central design detail in the home. Customize the glass railing to your preferences and experience a perfect balance between aesthetics and practical use.
See an example of: staircase with glass railing hidden fastening
Drömtrappor's glass railings offer a perfect balance between modern design, function and safety. You can tailor your staircase with glass railing to suit your style and needs. Glass railings create an airy, elegant feel and contribute to a safe solution for the whole family. Explore the possibilities and elevate your home with a staircase with glass railing from Drömtrappor.
