Hidden mounting with Mount In
Mount In – Concealed attachment
A staircase is an important part of the look and function of a home, and as a manufacturer of high-quality stairs with artisanal precision, we are constantly looking for new ways to improve our products – while making life a little easier for both the customer and the carpenter. That's why we have developed a fastening system that we call Mount In.
Since a staircase is manufactured in parts and assembled on site, there will always be fasteners on different parts of the structure, i.e. areas where the different parts are joined and fastened with screws. These fasteners are often visible on the stringer and affect the appearance of the staircase. MountIn ® is a patented fitting that gives the stringer a completely smooth exterior with a genuine quality construction. The assembly method provides a fastener below the landing, which means a significantly easier and less heavy job for our installers. It also allows the bolts in the staircase to be retightened after installation.
This is how it works
The step is still attached to the stringer as usual, but instead of screwing diagonally or driving a screw straight through the stringer, the step is mounted on the special fitting that is attached to the stringer. The fitting is attached through a cutout in the underside of the step. The hole, which is covered by a removable cover, makes it possible to retighten the bolts in the stairs if necessary.
Simplification of assembly
MountIn® enables assembly with time optimization in mind. One person can handle the assembly themselves.
Individual steps can be replaced without having to dismantle the entire staircase*. Because MountIn® Minimizes the need for heavy lifting during assembly, making the work less stressful for the carpenter, and also reduces the risk of damage to the surroundings and other furnishings. Since the ladder is bolted in, the ladder can be easily retightened and the stability increases over time. MountIn® is available as an option for all stairs with side rails.
*Assuming the stairs do not have walls on both sides. If the stairs are rebuilt with a storage room, the wall will be affected when changing steps.
