Renovate or replace stairs: what is best for your home?
ReStair® renovation or stair replacement
When it comes to updating your home, the staircase is often a central part that may need to be renovated or completely replaced. The choice between renovating or replacing your staircase depends on several factors such as budget, time and the style you want to achieve. Renovating or replacing your staircase may seem daunting and unnecessarily expensive, but there are several benefits worth considering. With ReStair® staircase renovation or replacement, you have the opportunity to optimize the space in your home, refresh its appearance and choose a new design that suits your style.
The benefits of replacing stairs
Replacing your stairs may seem daunting and unnecessarily expensive, but there are several benefits worth considering. You can also change the layout, which gives you the opportunity to optimize the space in your home. In addition, replacing your stairs makes it easier to paint and wallpaper around the stairs, which can give a fresher and more uniform look. You also have the opportunity to choose a staircase with a different design, which can renew the style of the entire home. Replacing your stairs does not necessarily have to be much more expensive than a renovation, and it provides more options, such as different types of wood. If you also want to replace the railings, handrails and balustrades, it is often economically advantageous to look at a completely new staircase.
Renovate the stairs
For many people considering renovating their stairs, the appearance of the stairs is the main reason. The stairs may be worn out after many years of use or simply feel outdated. There may also be damage or functional problems, such as creaking noises and loose steps. Renovating an existing staircase can be a cost-effective option and is especially suitable if the basic structure is solid but the surface is worn or outdated. A renovated staircase can look like new.
Renew your stairs with ReStair® stair renovation
With ReStair® stair renovation, it is easy to make your stairs look like new again. This complete system offers unique advantages. ReStair® ensures that your stairs not only look new and fresh, but also meet all important functional and safety requirements.
ReStair® – simple and effective stair renovation
ReStair® is an innovative stair renovation system that makes it easy to give your stairs a new lease of life. The system is based on renovation steps that are 9 mm thick, which contributes to increased stability while being sandable. This means you get the benefit of “two renovations in one” as the steps can be sanded and refinished if necessary. The material is thick enough to reduce the risk of future problems, without being so thick that it creates uneven step heights or makes the steps look bulky.
Two types of wood – many combinations
ReStair® is available in both oak and ash, two hard and durable types of wood. Oak has a slightly darker color that is excellent for both varnishing and oiling. Ash, with its lighter base tone, is particularly well suited for staining in different shades. These variations provide many combination options to customize the staircase to your personal style and taste. ReStair® is also available untreated if you prefer to treat the wood yourself.
Read more here about materials and options: ReStair® materials and options
Complete your ReStair® kit with wall handrails and railings
To complete your staircase renovation with ReStair®, you can complement it with matching wall handrails and railings. These are made from the same material as the ReStair® stairs, creating a uniform and stylish look. The handrails are designed to be easy to grip, which increases the safety and comfort of your staircase. They are delivered in standard lengths but can be easily cut to fit your specific needs. By adding wall handrails and railings, you can enhance the new feel and aesthetics of your staircase.
Read more about our guides and railings here:
Supervisor
The railing
Renovating or replacing your stairs is a decision that affects the look and functionality of your entire home. By carefully considering your needs and preferences, you can choose the best solution for your home – whether you choose a ReStair® renovation or a staircase replacement. We strive to create stairs that are not only beautiful and functional, but also imbued with a sense of warmth and attention to detail, making them a true joy to live with for years to come.
ReStair® is a registered trademark owned by Drömtrappor AB, the largest staircase manufacturer in the Nordic region. All ReStair® products are manufactured in Sweden and sold by retailers throughout the Nordic region.
www.restair.se
