Care advice
Stairs, and above all the steps, are generally subject to heavy wear.
Think of your staircase as you do with your other favorite pieces of furniture and take care of it in much the same way and you have come a long way, then follow our maintenance advice depending on the type of surface treatment you have chosen.
Solid Steel B
Side wing stairs with stainless steel railing posts in bent-glued design.
Oslo is a tight staircase with underlying stringers adapted for installation. Post with groove and cap, dimensions 115x115 mm. Uprights with similar pattern.
Spiral staircase Loop with bent-glued outer side railing entirely in oiled oak with stainless railing posts.
Optimal 56.34.3, solid staircase with matt lacquered oak steps, step nosing 2 and round wall handrail. Railings, stringers and risers painted white.
Staircase with stainless steel posts. Handrail and post in the same dimensions.
